Nidhal_KOTORSI's avatar
2 years ago
Transfer a property value to another item's property
Hi, I'm working with AML to update the Data in aras innovator. i'm stuck because i can't seem to transfer a property from one item to another. I have 2 items A and B. let us say that item A is a ...
    2 years ago
    for your use case you probably need two queries. The first one gets a value from the Part and the second one edits the Document.
    This not something you can do with Innovator Admin or similar tools. But it´s easy to do with a Method. You even could directly set the values via SQL (if you are familiar with the data structure and know what you do).
