Suhas
5 years agoCreator III
Timeout exception
If method execution time is more then timeout exception will occur it in that case method catch block will execute or not?
Regard,
Suhas
Regard,
Suhas
Hi Suhas,
there is a timeout exception class available So yes, a timeout can trigger a catch block. But it may not work for all use cases.
When I remember right, the WebClient class has no timeout property, so in this case it wouldn´t work and you have to google a workaround.
I tried many times but still can't find a solution on google bubble shooter
