team_aras_meupe_com's avatar
3 years ago
Thumbnail in TOC.
Hello, i seen in the PART that we can use a tumbnail and see it in the TOC. I try to do the same for other option in the TOC, but it dont work. I've looked everywhere, but I don't see any option...
    3 years ago
    Not sure if "thumbnail" can be used as foreign property in the properties pane sidebar. At least in OOTB Innovator.
    Foreign thumbnails works in Forms, cause the Form is designed to work with foreign properties. The sidebar is build differently. It made by a codetree function that collects the data to be shown in the sidebar.
    See ...\Client\javascript\ui_methodsEx.js . Search for "thumbnail" to find the function. The function contains code to handle item and date properties, but nothing to handle foreign. But you maybe can add this case your own.
    ui_methodEx.js contains a few other function that deal with foreign properties. Maybe you can reuse them.
    Strange behavior that you lost your original Part links when using the values in a foreign properties. Hope you use a test database. I don´t know this behavior and haven´t tested it. But it´s maybe a glitch. Image handling in Innovator is in general a bit glitched out and there are some image related operations that produce strange results. You always end up using a workaround.
