Kara's avatar
Kara
3 years ago
TGV Parameters Filtering doesn't show record if value is blank
Hello All,
I have created TGV on part and I have added parameters to search and filter on  custom "state" property . I have given default value as * .
It works well and able to search and filter on state column but there is one issue if any record has state "Blank" . That record is skipped from TGV results and which is causing me showing incorrect TGV results .
Help me to understand cause.
Thanks in advance .
  • Does the state have the name "Blank" or is it really blank (Null) ?
