rif6894
6 years agoCreator I
Technical Documentation - created_by_id and affected_part output
I am using the Technical Documentation application to create reports for the Quality Management qs_NCR ItemType. One of the qs_NCR properties is the affected_part which is implemented as an Item Item...
- 6 years ago
AJ
Thanks for your response. Based on your feedback I have implemented:
Innovator inn = this.Factory.InnovatorInstance;
Item item = inn.newItem("User", "get");
item.setID(targetItem.GetItemProperty("created_by_id", " "));
Item results = item.apply();
tableElement1.GetCell(0,4).AddChild(this.Factory.NewText("Title", results.getProperty("keyed_name")));
