rif6894's avatar
rif6894
Technical Documentation - created_by_id and affected_part output
I am using the Technical Documentation application to create reports for the Quality Management qs_NCR ItemType. One of the qs_NCR properties is the affected_part which is implemented as an Item Item...
  • rif6894's avatar
    rif6894
    AJ
    Thanks for your response. Based on your feedback I have implemented:
    Innovator inn = this.Factory.InnovatorInstance;
    Item item = inn.newItem("User", "get");
    item.setID(targetItem.GetItemProperty("created_by_id", " "));
    Item results = item.apply();
    tableElement1.GetCell(0,4).AddChild(this.Factory.NewText("Title", results.getProperty("keyed_name")));
