dkinsley
6 years agoCreator II
Hi Nathan,
Thank you for your reply. We are still using version 11 so when I go to the Field tab I can only change the field title font size and font type, not the field value font size. Mine is Tacoma size 8 and is a hyperlink (filed type is item).
Nathan
6 years agoCreator III
We are using 11 SP10. Seems a bit odd that you can't change the text size.
- dkinsley6 years agoCreator II
We have SP 5. If i change the font size, the word "State" changes but not the value of the field.
- Nathan6 years agoCreator III
I'm not sure if there is a way. I was reading this post from a couple of years ago talking about the form. I think the end of it includes to the text. I would play around with it to see if it can be done.
