Simple search not working on dynamically setting search value for Activity2 Itemtype?
Hi Team, I have Item A and have "Activity2" relationship Item. I m setting search value for one of the field in Activity2. On clicking of search it not working. Following is way I am setting fiel...
  • Former_Member's avatar
    Hi Christopher,
    Thank you for replying.
    I tried making tags capital but still due to some reason its not working.
    Finally I end up writing following code and it resulted output I required.
    //Getting Id's of Item that required using some logic
    var IDs = "6C8BA60B1D784925BEA21D234312EDD8,EF95B584FB5F46C5A6C38794A03653F8"
    //Getting values in array
    var tempArray = IDs.split(',');
    //Binding result to search dialog
    inArgs.QryItem.item.setAttribute("idlist", tempArray);
    Hope this help to others struggling from same problem.
    Thank you once again Christopher for every help and quick response
    Thanks & Regards
    Gaurav
