Nara's avatar
Nara
SignOff Tab is not working in Chrome
Hi Experts,
I am using Aras Innovator Version 11.0 SP9  Build: 6549
I have created a custom Item type and added SignOff Report Relationship.
SignOff Report relationship tab is working find in IE and FF, but in Chrome it is not working.
Appreciate any inputs.
Regards,
Nara
  • Hi Nara,
    does your Chrome console (F12) show any errors or warnings when you are trying to open the SignOff tab?
    Cheers,
    C
    • Nara's avatar
      Nara
      Hi Cogres,
      I tried import hot fixes, but it's not working.
      I got below console warning.
      [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
      using @ include.aspx?classes=ScriptSet1,TearOffMenuControllerNoCUI,pageReturnBlocker:5946
      When i trace the code, the warning got stopped at below line.
      xmlHttpRequest.open('GET', classUrl, false);
      Based on this site: https://xhr.spec.whatwg.org/
      xmlHttpRequest.open('GET', classUrl, false); this method has changed to
      xmlHttpRequest.open('GET', classUrl);
      if i change my code as per above line, i see empty landing page.
      Regards
      Nara
    • Nara's avatar
      Nara
      Thanks Suhas,
      After importing above packages, my issue has not fixed.
      Regards
      Nara
