Yoann_Maingon
9 years agoAccelerator I
I think the idea you have is good.
I would investigate if claiming a task in the in basket triggers the update event on the workflow activity. If so you can then link you method to this event, you would then make sure that you have only one person assigned. As long as no-one claims the task, you keep the owner empty.
Makes sense?
