8 years agoAccelerator III
A couple ways to check is by the "event" of the method...(beforeUpdate, beforeAdd, afterPromote, etc). There is an order of operation, i believe, as to what events get fired off first. If they are both the same event then you can look at the sort order. The execution of methods, as i understand it, goes in order per type. so lowest "sort order" goes first for each event
example:
onBeforeAdd_Method_1 - sort order 10 goes first
onBeforeAdd_Method_1 - sort order 20 goes second etc...
or, if you are able to, enable debugging and put a break point in each method. see what gets hit first.
does this help?
