Typically the error message is more tuned. For example, in my environment, the error message with your original code is instead:
Line number 3, Error Number: BC30516, Overload resolution failed because no accessible 'setProperty' accepts this number of arguments.
Much more helpful than the message you were seeing. Could you please confirm which version of Aras Innovator you are using?
Additionally, it's possible that this is a permissions issue preventing the temporary files from being created in the /dll/ folder. Could you also check the folder permissions of the /dll/ folder referenced in your original error message?
_______________________________________________
