Hi Gopikrishnan,
Thank you for your kindly reply!
I did not get any error from Aras GUI, just did not get any email when using onAfterUnlock.
But from the log file, I found following:
<LOGFILE>
<event time="2020-06-03 20:51:56Z" reason="soap_action" TickCount="113254250" dt="0" message="ApplyItem" />
<event time="2020-06-03 20:51:56Z" reason="requestDom" TickCount="113254250" dt="0" />
<SOAP-ENV:Body>
<ApplyItem>
<Item type="DLV_ActionReq" id="F9732A7FC25144A481100EDF91582DB1" action="unlock" />
</ApplyItem>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
<event time="2020-06-03 20:51:56Z" reason="cachedriver-key" TickCount="113254265" dt="15" message="GetMethodFromCache:A1C22425BF134F46833FA6E8AAA21348:en" />
<event time="2020-06-03 20:51:56Z" reason="cachedriver-value" TickCount="113254265" dt="0" message="Aras.Server.Core.CacheMethodInfo" />
<event time="2020-06-03 20:51:56Z" reason="NewID" TickCount="113254265" dt="0" message="1563BFE4DA9245299CAD37B38DFF1BF6" />
<event time="2020-06-03 20:51:56Z" reason="cachedriver-key" TickCount="113254500" dt="235" message="GetItemTypeIdFromCache:Email Message:en" />
<event time="2020-06-03 20:51:56Z" reason="cachedriver-value" TickCount="113254500" dt="0" message="Aras.Server.Core.ItemTypeIdInfo" />
<event time="2020-06-03 20:51:56Z" reason="cachedriver-key" TickCount="113254500" dt="0" message="GetServerEventsFromCache:F91DE6AE038A4CC8B53D47D5A7FA49FC:en" />
<event time="2020-06-03 20:51:56Z" reason="cachedriver-value" TickCount="113254500" dt="0" message="Aras.Server.Core.MetaDataInfo.ServerEventsList" />
<event time="2020-06-03 20:51:56Z" reason="cachedriver-key" TickCount="113254500" dt="0" message="GetRelListFromCache:F91DE6AE038A4CC8B53D47D5A7FA49FC:False:en" />
<event time="2020-06-03 20:51:56Z" reason="cachedriver-value" TickCount="113254500" dt="0" message="Aras.Server.Core.RelTypesList" />
<event time="2020-06-03 20:51:56Z" reason="cachedriver-key" TickCount="113254500" dt="0" message="AllowedPermissionsList:F91DE6AE038A4CC8B53D47D5A7FA49FC:en" />
<event time="2020-06-03 20:51:56Z" reason="cachedriver-value" TickCount="113254500" dt="0" message="Aras.Server.Core.PermissionsList" />
<event time="2020-06-03 20:51:56Z" reason="performance" TickCount="113254500" dt="0" message="250" />
<event time="2020-06-03 20:51:56Z" reason="responseDom" TickCount="113254500" dt="0" />
<SOAP-ENV:Body>
<Result>
<Item type="DLV_ActionReq" typeId="B860EC10B74C40C089BA76FC4C41B26C" id="F9732A7FC25144A481100EDF91582DB1">
<classification>Internal</classification>
<config_id keyed_name="ACT-00000015" type="DLV_ActionReq">F9732A7FC25144A481100EDF91582DB1</config_id>
<created_by_id keyed_name="Admin: Jimmi Yang" type="User">17E2112E82C745DCA979A95EB4B030C2</created_by_id>
<created_on>2020-06-02T16:23:38</created_on>
<current_state name="Created" keyed_name="Created" type="Life Cycle State">70ADED32721B485982F4446B3B7CCB05</current_state>
<dlv_assignedto keyed_name="Jimmi Yang" type="User">BA68B9B4A8AF4EA2B255B5D1AB0C9E25</dlv_assignedto>
<dlv_create_edit_usr>0</dlv_create_edit_usr>
<dlv_customer keyed_name="Admin: Jimmi Yang" type="User">17E2112E82C745DCA979A95EB4B030C2</dlv_customer>
<dlv_description>fdgdfgsfsfdsdf</dlv_description>
<dlv_effectmanual>1</dlv_effectmanual>
<dlv_estwork>Hours</dlv_estwork>
<dlv_ext_usr>0</dlv_ext_usr>
<dlv_header>fgdfg update</dlv_header>
<dlv_int_usr>0</dlv_int_usr>
<dlv_prio>Low</dlv_prio>
<dlv_requested_by keyed_name="Admin: Jimmi Yang" type="User">17E2112E82C745DCA979A95EB4B030C2</dlv_requested_by>
<dlv_searchdata_usr>0</dlv_searchdata_usr>
<dlv_status>Received</dlv_status>
<dlv_taskcategory>Maintain Data</dlv_taskcategory>
<dlv_upload_doc_usr>0</dlv_upload_doc_usr>
<generation>1</generation>
<id keyed_name="ACT-00000015" type="DLV_ActionReq">F9732A7FC25144A481100EDF91582DB1</id>
<is_current>1</is_current>
<is_released>0</is_released>
<keyed_name>ACT-00000015</keyed_name>
<major_rev>A</major_rev>
<modified_by_id keyed_name="Admin: Jimmi Yang" type="User">17E2112E82C745DCA979A95EB4B030C2</modified_by_id>
<modified_on>2020-06-03T14:36:35</modified_on>
<new_version>1</new_version>
<not_lockable>0</not_lockable>
<permission_id keyed_name="DLV_New" type="Permission">80A688D56E2D42B0A210E0D083196B97</permission_id>
<state>Created</state>
<team_id keyed_name="DL Process" type="Team">915EAEE1BC2845848C6F551E2AADCC21</team_id>
<item_number>ACT-00000015</item_number>
</Item>
</Result>
<Message>
<event name="ids_modified" value="F9732A7FC25144A481100EDF91582DB1" />
</Message>
</SOAP-ENV:Body>
<event time="2020-06-03 20:51:56Z" reason="soap_action" TickCount="113254562" dt="0" message="ApplyItem" />
<event time="2020-06-03 20:51:56Z" reason="requestDom" TickCount="113254562" dt="0" />
<SOAP-ENV:Body>
<ApplyItem>
<Item type="ItemType" action="get" select="id, name, label">
<Relationships>
<Item type="Morphae" action="get" select="id">
<related_id>B860EC10B74C40C089BA76FC4C41B26C</related_id>
</Item>
</Relationships>
</Item>
</ApplyItem>
</SOAP-ENV:Body>
<event time="2020-06-03 20:51:56Z" reason="performance" TickCount="113254562" dt="0" message="0" />
<event time="2020-06-03 20:51:56Z" reason="responseDom" TickCount="113254562" dt="0" />
<SOAP-ENV:Body>
<faultcode>0</faultcode>
<faultstring><![CDATA[No items of type ItemType found.]]></faultstring>
<detail>
<af:legacy_detail><![CDATA[No items of type ItemType found.]]></af:legacy_detail>
<af:legacy_faultstring><![CDATA[No items of type 'ItemType' found using the criteria:
<Item type="ItemType" action="get" select="id, name, label"><Relationships><Item type="Morphae" action="get" select="id"><related_id>B860EC10B74C40C089BA76FC4C41B26C</related_id></Item></Relationships></Item>
]]></af:legacy_faultstring>
<af:legacy_faultactor> at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo)
at System.Environment.get_StackTrace()
at Aras.Server.Core.XML.SetErrorMessageImplementation(XmlDocument xmlDom, String faultCode, String faultString, String legacyFaultString, String stackTrace) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\Xml\xml.cs:line 662
at Aras.Server.Core.XML.Aras.Server.Core.IXml.SetErrorMessage(XmlDocument xmlDom, XmlQualifiedName faultCode, String faultString, String legacyFaultString) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\Xml\xml.cs:line 195
at Aras.Server.Core.GetItemProxy.SetNoItemsFoundFaultCode(XmlDocument dom, String itemTypeName, XmlNode criteriaNode) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\GetItem\GetItem.cs:line 623
at Aras.Server.Core.GetItemProxy.GetItem_DefaultImplementation(XmlElement item, XmlDocument inDom, XmlDocument outDom, ItemTypeInfo itemType, Boolean maxGeneration, Boolean forceIgnorePermissions, InnovatorDBCommandParameterCollection pars, Int32 curLevel, Int32 maxLevel) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\GetItem\GetItem.cs:line 1734
at Aras.Server.Core.GetItemProxy.GetItem_Implementation(XmlElement criteriaItem, Boolean maxGeneration, Int32 curLevel, Int32 maxLevel, Boolean forceIgnorePermissions, XmlDocument outDom) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\GetItem\GetItem.cs:line 1628
at Aras.Server.Core.GetItemProxy.GetItemInternal(XmlDocument itemDom, XmlDocument passedResponseDom) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\GetItem\GetItem.cs:line 700
at Aras.Server.Core.ApplyItemProxy.ApplyItem(XmlDocument& inDom, AddItemImplementationAdditionalInfo additionalItemInfo, XmlDocument& outDom) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\ApplyItem.cs:line 562
at Aras.Server.Core.ApplyItemProxy.Aras.Server.Core.IApplyItem.ApplyItem(XmlDocument inDom, XmlDocument outDom) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\ApplyItem.cs:line 284
at Aras.Server.Core.ApplySoapAction.Apply(String soapAction, XmlDocument inDom, XmlDocument outDom, Boolean securityCheck) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\ApplySoapAction.cs:line 130
at Aras.Server.Core.SoapActionRequestController.ProcessSoapAction(String soapAction, XmlDocument requestDom) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\RequestControllers\SoapActionRequestController.cs:line 263
at Aras.Server.Core.SoapActionRequestController.GetResponse() in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\RequestControllers\SoapActionRequestController.cs:line 105
at Aras.Server.Core.SoapActionRequestController.ProcessRequest() in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\RequestControllers\SoapActionRequestController.cs:line 57
at Aras.Server.Core.Startup.InnovatorServerMain() in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Core\Startup.cs:line 27
at Aras.Web.Server.InnovatorServer.OnLoad(EventArgs e) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Aras.Web.Server\InnovatorServer.cs:line 17
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
at System.Web.HttpApplication.PipelineStepManager.ResumeSteps(Exception error)
at System.Web.HttpApplication.BeginProcessRequestNotification(HttpContext context, AsyncCallback cb)
at System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context)
at System.Web.Hosting.PipelineRuntime.ProcessRequestNotificationHelper(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)
at System.Web.Hosting.PipelineRuntime.ProcessRequestNotification(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)
at System.Web.Hosting.UnsafeIISMethods.MgdIndicateCompletion(IntPtr pHandler, RequestNotificationStatus& notificationStatus)
at System.Web.Hosting.PipelineRuntime.ProcessRequestNotification(IntPtr rootedObjectsPointer, IntPtr nativeRequestContext, IntPtr moduleData, Int32 flags)</af:legacy_faultactor>
</detail>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
<event time="2020-06-03 20:51:56Z" reason="soap_action" TickCount="113254750" dt="0" message="ApplyItem" />
<event time="2020-06-03 20:51:56Z" reason="requestDom" TickCount="113254750" dt="0" />
<SOAP-ENV:Body>
<ApplyItem>
<Item type="DLV_ActionReq_File" action="get" page="1" select="id,created_by_id,created_on,modified_by_id,modified_on,locked_by_id,major_rev,css,current_state,keyed_name,related_id(comments,file_type,indexed_on,created_by_id,created_on,modified_by_id,modified_on,locked_by_id,major_rev,css,current_state,keyed_name),source_id" pagesize="" returnMode="itemsOnly">
<source_id condition="eq">F9732A7FC25144A481100EDF91582DB1</source_id>
</Item>
</ApplyItem>
</SOAP-ENV:Body>
<event time="2020-06-03 20:51:56Z" reason="performance" TickCount="113254765" dt="15" message="15" />
<event time="2020-06-03 20:51:56Z" reason="responseDom" TickCount="113254765" dt="0" />
<SOAP-ENV:Body>
<faultstring><![CDATA[No items of type DLV_ActionReq_File found.]]></faultstring>
<detail>
<af:legacy_detail><![CDATA[No items of type DLV_ActionReq_File found.]]></af:legacy_detail>
<af:legacy_faultstring><![CDATA[No items of type 'DLV_ActionReq_File' found using the criteria:
<Item type="DLV_ActionReq_File" action="get" page="1" select="id,created_by_id,created_on,modified_by_id,modified_on,locked_by_id,major_rev,css,current_state,keyed_name,related_id(comments,file_type,indexed_on,created_by_id,created_on,modified_by_id,modified_on,locked_by_id,major_rev,css,current_state,keyed_name),source_id" pagesize="" returnMode="itemsOnly"><source_id condition="eq">F9732A7FC25144A481100EDF91582DB1</source_id></Item>
</detail>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
<event time="2020-06-03 20:51:56Z" reason="soap_action" TickCount="113254890" dt="0" message="applyaml" />
<event time="2020-06-03 20:51:56Z" reason="requestDom" TickCount="113254890" dt="0" />
<AML>
<Item type="RelationshipType" action="get" select="name,label,auto_search,copy_permissions,core,default_page_size,description,grid_view,hide_in_all,inc_rel_key_name,inc_related_key_name,is_list_type,max_occurs,min_occurs,new_show_related,related_notnull,related_option,create_related,use_src_access,source_id,relationship_id,related_id" related_expand="0" isCriteria="0">
<id>Parameters</id>
<Relationships>
<Item type="Relationship View" action="get" select="form,grid,start_page,parameters,related_id" related_expand="0" isCriteria="0" />
<Item type="Relationship Grid Event" action="get" select="grid_event,related_id(name,method_type,method_code)" isCriteria="0" />
</Relationships>
</Item>
</AML>
<event time="2020-06-03 20:51:56Z" reason="soap_action" TickCount="113254937" dt="0" message="ApplyItem" />
<event time="2020-06-03 20:51:56Z" reason="requestDom" TickCount="113254937" dt="0" />
<SOAP-ENV:Body>
<ApplyItem>
<Item isNew="1" isTemp="1" type="SQL" action="DLV_COUNTS_ON_TABS_SERVER">
<relshipTypeName>DLV_ActionReq_File|DLV_ActionReq_ActionReq|DLV_ActionReq_RefBy|DLV_ActionReq_Subscribers|DLV_ActionReq_User</relshipTypeName>
<id>F9732A7FC25144A481100EDF91582DB1</id>
</Item>
</ApplyItem>
</SOAP-ENV:Body>
<event time="2020-06-03 20:51:56Z" reason="SQL Process inDom" TickCount="113254937" dt="0" />
<Item isNew="1" isTemp="1" type="SQL" action="SQL PROCESS">
<name>dlv_cnt_tab_rels</name>
<PROCESS>CALL</PROCESS>
<ARG1>F9732A7FC25144A481100EDF91582DB1</ARG1>
<ARG2>DLV_ActionReq_File|DLV_ActionReq_ActionReq|DLV_ActionReq_RefBy|DLV_ActionReq_Subscribers|DLV_ActionReq_User</ARG2>
</Item>
<event time="2020-06-03 20:51:56Z" reason="SQL Process db_item" TickCount="113254937" dt="0" />
</Item>
<event time="2020-06-03 20:51:56Z" reason="SQL Process outDom" TickCount="113254937" dt="0" />
<SOAP-ENV:Body>
<Result>
<Item>
<ant>0|0|0|0|0|</ant>
</Item>
</Result>
</SOAP-ENV:Body>
<event time="2020-06-03 20:51:56Z" reason="performance" TickCount="113254937" dt="0" message="0" />
<event time="2020-06-03 20:51:56Z" reason="responseDom" TickCount="113254937" dt="0" />
<SOAP-ENV:Body>
<Result>
<Item>
</Item>
</Result>
</SOAP-ENV:Body>
