are you sure VC really need the Document ItemType? It is probably possibe to import only Document related item from the original PLM solution package. But I remember a similar error message from a previous issue with vc.
Do you use any reference to the Document ItemType that is maybe not needed at all?
Go to your ItemType and open the 'Secure Social' tab. Do you have reference to the Document ItemType in one of the Templates?
- miraks7 years agoCreator II
Q1- Are you sure VC really need the Document ItemType?
R1- Yes, I am. I imported only the Document object from the PLM package, and now "Secure Social" works well.
Q2- Do you use any reference to the Document ItemType that is maybe not needed at all?
R2- No
Q3- Go to your ItemType and open the 'Secure Social' tab. Do you have reference to the Document ItemType in one of the Templates?
R3- No
For me, this issue is closed.
The solution is: "You must install Document (from PDM) if you want to use Social Secure".
