8 years agoCatalyst II
I think you could add one additional level under your "Affected Item" query. Both "new_item_id" and "affected_id" use the PolyItem "ChangeControlledItem". This PolyItems combines the ItemType "Part", "Document" and "CAD".
In "ChangeControlItem" you can search for distinct ItemTypes, like "Document" by setting a filter on the property "itemtype".
Different nomenclature, but something like this:
Item ChCtrI = inn.newItem("Change Controlled Item","get");
ChCtrI.setAttribute("select","id,item_number");
ChCtrI.setProperty("id",new_item_id);
ChCtrI.setProperty("itemtype", "Document");
ChCtrI=ChCtrI.apply();
