eli_donahue
1 year agoCommunity Manager
Hi Rob,
Responsive forms currently don't support Javascript methods for field or form events. Instead, the goal is to use rules and data store events for custom logic rather than events tied to DOM elements in the form. This approach will help provide a more consistent experience because data store events trigger any time client data is updated - not just when a form control is updated.
Does your use case require setting a field value on initial load or when some data on the form changes?
Rob_Cohen
1 year agoIdeator I
Hi Eli,
Basically I want several fields be auto-filled when the user clicks an Action item in the toolbar or presses a button.
Thanks,
Rob
