This one requires some background information first.
1. Do you use the Aras Office Connector?
2. Why do you want to use all available Method events types (onBeforeLock??)? Do you really want to rename your document every time "something" happens?
3. onAfterAdd/Update/Version should do the job. Which code do you use for updating the item?
I only want to use one event type if possible. We are using the connector, however I attempted each type due to the fact that none of them were able to complete the task without issue. The closest and most ideal would be OnAfterUpdate however the office connector throws the error.
Here is the code:
[embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:b1a81315-4fd6-43b6-b279-fd245f1fdff7:type=csharp&text=Innovator%20inn%20%3D%20this.getInnovator%28%29%3B%0D%0Astring%20sourceId%20%3D%20this.getID%28%29%3B%0D%0A%0D%0AString%20relationshipName%3B%0D%0A%2F%2F%2CsouceProperty%2C%20sourceContentLocation%3B%0D%0A%0D%0A%2F%2FItem%20queryFile%2C%20%0D%0AItem%20item%2C%20files%2C%20file%3B%0D%0A%0D%0A%2F%2Ffiletype%20or%20doc%20validation%20if%20reuqired%0D%0Aif%20%28true%29%20%7B%0D%0A%20%20%20%20relationshipName%20%3D%20%22Document%20File%22%3B%0D%0A%0D%0A%20%20%20%20item%20%3D%20this.newItem%28%22Document%22%2C%20%22get%22%29%3B%0D%0A%20%20%20%20item.setProperty%28%22id%22%2C%20sourceId%29%3B%0D%0A%20%20%20%20Item%20isRelationship%20%3D%20this.newItem%28relationshipName%2C%20%22get%22%29%3B%0D%0A%20%20%20%20item.addRelationship%28isRelationship%29%3B%0D%0A%20%20%20%20item%20%3D%20item.apply%28%29%3B%0D%0A%0D%0A%2F%2Fget%20all%20Documet%20Files%20%0D%0A%20%20%20%20files%20%3D%20item.getRelationships%28relationshipName%29%3B%0D%0A%20%20%20%20%0D%0A%20%20%20%20%2F%2FTo%20iterate%20through%20attached%20files%0D%0A%20%20%20%20for%20%28int%20i%20%3D%200%3B%20i%20%3C%20files.getItemCount%28%29%3B%20i%2B%2B%29%20%7B%0D%0A%20%20%20%20%20%20%20%20file%20%3D%20files.getItemByIndex%28i%29%3B%0D%0A%20%20%20%20%20%20%20%20file%20%3D%20file.getRelatedItem%28%29%3B%0D%0A%0D%0A%2F%2Fstring%20to%20be%20added%20into%20filename%0D%0A%20%20%20%20%20%20%20%20string%20stringToRenameFile%20%3D%20this.getProperty%28%22item_number%22%29%20%2B%20%22%20%22%2B%20this.getProperty%28%22name%22%29%20%2B%20%22%20%22%20%2B%20this.getProperty%28%22major_rev%22%29%20%2B%20%22v%22%20%2B%20this.getProperty%28%22generation%22%29%3B%0D%0A%0D%0A%20%20%20%20%20%20%20%20string%20fileId%20%3D%20file.getID%28%29%3B%0D%0A%20%20%20%20%20%20%20%20string%20fname%20%3D%20file.getProperty%28%22filename%22%29%3B%0D%0A%0D%0A%20%20%20%20%20%20%20%20string%5B%5D%20array%20%3D%20fname.Split%28%27.%27%29%3B%0D%0A%20%20%20%20%20%20%20%20fname%20%3D%20string.Empty%3B%0D%0A%20%20%20%20%20%20%20%20if%20%28array.Length%20%3D%3D%201%29%20%7B%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20fname%20%3D%20stringToRenameFile%20%2B%20array%5B1%5D%3B%0D%0A%20%20%20%20%20%20%20%20%7D%20else%20%7B%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20for%20%28int%20j%20%3D%200%3B%20j%20%3C%20array.Length%3B%20j%2B%2B%29%20%7B%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20fname%20%2B%3D%20array%5Bj%5D%3B%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20if%20%28j%20%3D%3D%20array.Length%20-%202%29%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20if%20%28j%20%21%3D%20array.Length%20-%201%29%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7B%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20fname%20%3D%20stringToRenameFile%3B%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20fname%20%3D%20stringToRenameFile%20%2B%20%22.%22%3B%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7D%0D%0A%20%20%20%20%20%20%20%20%7D%0D%0A%20%20%20%20%20%20%20%20file%20%3D%20this.newItem%28%22File%22%29%3B%0D%0A%20%20%20%20%20%20%20%20file.setAttribute%28%22action%22%2C%20%22RenameFile%22%29%3B%0D%0A%20%20%20%20%20%20%20%20file.setID%28fileId%29%3B%0D%0A%20%20%20%20%20%20%20%20file.setProperty%28%22filename%22%2C%20fname%29%3B%0D%0A%0D%0A%20%20%20%20%20%20%20%20%2F%2F%20to%20get%20root%20user%20permission%20via%20identity%0D%0A%20%20%20%20%20%20%20%20Aras.Server.Security.Identity%20identity%20%3D%20Aras.Server.Security.Identity.GetByName%28%22Super%20User%22%29%3B%0D%0A%20%20%20%20%20%20%20%20bool%20permsWasSet%20%3D%20Aras.Server.Security.Permissions.GrantIdentity%28identity%29%3B%0D%0A%0D%0A%20%20%20%20%20%20%20%20file%20%3D%20file.apply%28%29%3B%0D%0A%0D%0A%20%20%20%20%20%20%20%20%2F%2Facquired%20root%20user%20permission%20should%20be%20revoked%0D%0A%20%20%20%20%20%20%20%20if%20%28permsWasSet%29%0D%0A%20%20%20%20%20%20%20%20%20%20%20%20Aras.Server.Security.Permissions.RevokeIdentity%28identity%29%3B%0D%0A%20%20%20%20%7D%0D%0A%7D%0D%0Areturn%20this%3B]
