Morgan's avatar
Morgan
Creator III
4 years ago
Remove a saved search from TOC
Hi Community,
I have a saved search that was shared to an identity group. I updated the owned_by_id which based on documentation should control who has access but it is still showing up in this identity's TOC panel. How can I remove access to this search via the ToC sidebar?
  • Where do you use the owned_by_id? Have you modified the SavedSearch item directly?
    • Morgan's avatar
      Morgan
      Creator III
      Hello Angela,
      I have modified the saved search item directly.
        I don´t remember exactly, but I assume you also have to modify the managed_by_id.
        In my case I always delete corrupted SavedSearch completely and then rebuild them from the scratch.
        Edit: It can also happen that you have duplicate entries for the same SavedSearch. It would also check for this one.
