relationshipType api rest
Hi community,
I'm trying to get the list of all the relationshipTypes of an ItemType thanks to the REST API.
Is this possible ?
Thanks for any help !
Arnaud
  • asebastian's avatar
    asebastian
    Hi Arnaud,
    You should be able to do this by querying the "ItemType" ItemType, and returning the "relationshipType" relationship. More in depth information about how to create queries like this can be found in this blog post.
    AJ
    • Former_Member's avatar
      Hi Sebastian,
      Thank you for the answer, I'm already using this blog but I didn't find the answer... What is the url used to perform this task ? I already tried plenty of things.
      I should start with : localhost/.../
      But then how can I add  "relationshipType" to get the list I need ?
      I often get the error message "notImplemented".
      Best regards
      • cogres's avatar
        cogres
        Creator III
        Hi Arnaud,
        your request should look something like this
        GET    <URI for your Aras Installation>/server/odata/ItemType('<ID for the ItemType you want to query>')/RelationshipType
        You will need to replace <URI for your Aras Installation> in the URI with the path for your Aras installation (like http://localhost/InnovatorServer) and the given <ID for the ItemType you want to query> with the ID of the ItemType you want to know the RelationshipTypes for.
        Is this what you need?
