I asked Rolf about this at ACE Europe and he kindly mailed me the following:
This is a sample how to create a JS library i.e. with your own utility functions to be used on every Form or other client side JS code,
NOTICE: changes to the code tree are necessary !!! You will have to redo these changes on every upgrade.
(1) Create a JS file with a class of your utility functions. In this case we call it "FormUtilities.js".
Sample functions in FormUtilities.js could be:
// Library Class
FormUtilities = function () {
//variables
this.varibale_1 = "XX";
// Library functions
FormUtilities.prototype.showFormFieldByPropName = function FormUtilities_showFormFieldByPropName(propName, show) {
var field = getFieldByName(propName);
if (field)
var visibility = show ? "visible" : "hidden";
var display = show ? "" : "none";
var fieldStyle = field.style;
fieldStyle.visibility = visibility;
fieldStyle.display = display;
FormUtilities.prototype.showFormFieldByFieldName = function FormUtilities_showFormFieldByFieldName(fieldName, show) {
var field = document.getElementsByName(fieldName)[0];
if (field)
(2) copy this JS file to the code tree of your Aras Installation.
Go to folder …innovator/client/javascript
Add a folder for your library.. In this case we create a folder "Customer" copy your JS file into this folder.
(3) register your JS file in several Aras config files (make backup copies of files before you edit them !!!)
In your code tree edit file ... Innovator\Client\javascript\IncludeNamespaceConfig.xml
Find tag </JavaScriptNamespace>
Insert following row before this tag:
<class name="/FormUtilities" src="Customer\FormUtilities.js"/>
Save and close the file.
In your code tree edit file ... innovator\Client\Modules\aras.innovator.core.Form\Views\FormInstance.cshtml
Find tag <script type="text/javascript" src="@Url.ContentWithSalt("~/javascript/include.aspx?classes=/dojo.js")"
<script type="text/javascript" src="@Url.ContentWithSalt("~/javascript/include.aspx?classes=/FormUtilities")"></script>
In your code tree edit file ... innovator\Client\Modules\aras.innovator.core.ItemWindow\Views\Shared\_Layout.cshtml
(4) Use library function on a Form logic.
In this example we add a JS-Method to the "Part" form onto form event "onLoad".
JS-Method "testingFormUtilities":
var fu = new FormUtilities();
fu.showFormFieldByPropName("description", false);
==> the effect now is that when you open a "Part" the description field will not be shown.
