dkinsley's avatar
dkinsley
2 years ago
Query help needed
Can someone help me with an AML query to find... all of our parts in Innovator that have only one item in the EBOM what revision sequence each part is assigned what the single EBOM item part ...
  • asebastian's avatar
    asebastian
    2 years ago
    I went ahead and whipped up a quick method which you can add to your instance and execute to get all the parts with exactly 1 BOM Relationship:
    [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:d4e06a2a-e62e-40f1-81f1-ba4ed2737dd7:type=text&text=var%20inn%20%3D%20this.getInnovator%28%29%3B%0D%0A%0D%0Avar%20parts%20%3D%20inn.newItem%28%22Part%22%2C%22get%22%29%3B%0D%0Aparts%20%3D%20parts.apply%28%29%3B%0D%0AList%3Cstring%3E%20relPartList%20%3D%20new%20List%3Cstring%3E%28%29%3B%0D%0AList%3Cstring%3E%20sourcePartList%20%3D%20new%20List%3Cstring%3E%28%29%3B%0D%0Afor%20%28int%20i%20%3D%200%3B%20i%20%3C%20parts.getItemCount%28%29%3B%20i%2B%2B%29%7B%0D%0A%20%20var%20currPart%20%3D%20parts.getItemByIndex%28i%29%3B%0D%0A%20%20var%20bomRel%20%3D%20inn.newItem%28%22Part%20BOM%22%2C%22get%22%29%3B%0D%0A%20%20bomRel.setProperty%28%22source_id%22%2CcurrPart.getID%28%29%29%3B%0D%0A%20%20bomRel%20%3D%20bomRel.apply%28%29%3B%0D%0A%20%20if%20%28bomRel.getItemCount%28%29%20%3D%3D%201%29%7B%0D%0A%20%20%20%20relPartList.Add%28bomRel.getProperty%28%22related_id%22%29%29%3B%0D%0A%20%20%20%20sourcePartList.Add%28currPart.getID%28%29%29%3B%0D%0A%20%20%7D%0D%0A%7D%0D%0A%0D%0Areturn%20inn.newResult%28%22Parts%20with%201%20Item%20in%20EBOM%3A%20%22%20%2B%20String.Join%28%22%2C%22%2CsourcePartList%29%29%3B]
    To utilize this, you can create a new method in Innovator, make sure it's a server method. Then once it's saved you should be able to run the following action (Run Server Method):
    The output should pop up. It'll be a list of IDs for all the parts that have exactly 1 BOM Relationship. After that you should be able to use that list for an AML Query using the idlist attribute.
    AJ
