9 years agoAccelerator III
Hi Yoann,
same case, I am also facing.
I have attached some related items of item type "CAD" using relationships in "Part" item type instance. Part has it's own workflow and Lifecycle. I can promote the part using promotions in workflow.
"While promoting Part, I want to promote the state of related items(CAD Docs) also."
Que 1.- Is it mandatory to create a separate workflow for "CAD" item type ? (I do not want extra notifications in "My basket" for CAD Doc promotion)
Que 2- Is there is any way to control lifecycle of related item (CAD DOC) directly using server methods from "Part" workflow..?
If yes, Please share some sample code...
Right now I am using this in server event on "Part" workflow-
(CAD item type has sepearate Lifecycle with no workflow process)
Aras.Server.Security.Identity roleIden = Aras.Server.Security.Identity.GetByName("Owner"); //–Your Transition's Role here
bool SetPermission = Aras.Server.Security.Permissions.GrantIdentity(roleIden);
var cad_docs = "<Item type='CAD' action='promoteItem' where=\"[CAD].item_number='"+itm_num+"'\">" +
"<state>In Review</state>" +
"</Item>";0
doc_itm.loadAML(cad_docs);
var results = doc_itm.apply();
It's showing error "Internal Error: failed to get the transition to promote the CAD from Preliminary to In Review".
Any help is appreciated and thanks in advance.
- Florian127 years agoIdeator III
I am facing the same issues and have no clue how to program with AML.
Have you any code you can share? This would help a lotBest regards,
Florian
