Problem with the use of dates.
- 3 years ago
it should not be necessary to hard-code the time zone difference. Cause this could lead to trouble with summer/winter time changes.
I so far didn´t needed "get" queries that required exact hour/minutes filters so I right now don´t know a solution for your scenario. I most of the time just "write" timings. I wonder if and how the regular grid search options consider the time zone difference.
I think as the date is stored in neutral format, you also must use neutral format when searching. So convert your current date to neutral before using it as filter.
Have you checked the internationalization guide? It contains a few code samples regarding writing the time in neutral format.
www.aras.com/.../aras-innovator-120--configuring-internationalization.ashx
