Ashok_Yadav's avatar
Ashok_Yadav
3 years ago
predecessor Number Value For Activity2
Hi Guys,
Can you please help me to find out value of  predecessor Number Value For Activity2 by Method .
For project Management .
Thank in Advance.
    • Ashok_Yadav's avatar
      Ashok_Yadav
      Hope below code work for you
      Item GetActivitiesNumbers = inn.newItem("Method");
      //GetActivitiesNumbers.setProperty("name", "GetActivitiesNumbers");
      GetActivitiesNumbers.setProperty("rootWBS",WBS_ElemenRS2ID);
      Item resultItem = GetActivitiesNumbers.apply("GetActivitiesNumbers");
      new ND_Log().SetUserID("resultItem: " + resultItem, user_id, logfilePath);
      doc.LoadXml(resultItem.ToString());
      XmlElement myElement = doc.DocumentElement;
      // Create an attribute collection from the element.
      XmlNodeList AactiviElement =myElement.GetElementsByTagName("a");
      //new ND_Log().SetUserID("AactiviElement.Count: " + AactiviElement.Count, user_id, logfilePath);
      for (int actidnum=0; actidnum< AactiviElement.Count; actidnum++)
      string id = AactiviElement[actidnum].Attributes["id"].Value;
      new ND_Log().SetUserID("id: " + id, user_id, logfilePath);
      string number = AactiviElement[actidnum].Attributes["number"].Value;
      inn.applySQL("update innovator.Activity2 set nd_number='" + number + "' where id='" + id + "' ");
      // Activity 2
      Item act2 = inn.newItem();
      Item acti2 = inn.newItem();
      Item actPredecessor = inn.newItem();
      actPredecessor.loadAML("<Item type='Activity2' action='get' select='id,name,proj_num,date_start_sched,date_due_sched,nd_date_start_schedbase1,nd_date_due_schedbase1,nd_date_start_schedbase2,nd_date_due_schedbase2,nd_date_start_schedbase3,nd_date_due_schedbase3,nd_date_start_schedbase4,nd_date_due_schedbase4,nd_date_start_schedbase5,nd_date_due_schedbase5,nd_date_start_schedbase6,nd_date_due_schedbase6,nd_date_start_schedbase7,nd_date_due_schedbase7,nd_date_start_schedbase8,nd_date_due_schedbase8,nd_date_start_schedbase9,nd_date_due_schedbase9,nd_date_start_schedbase10,nd_date_due_schedbase10,percent_compl,expected_duration,nd_status'>" +
      "<proj_num condition='eq'>" + project_number + "</proj_num>" +
      "</Item>");
      Item actPredecessor2 = actPredecessor.apply();
      int actPredecessor2Count = actPredecessor2.getItemCount();
      new ND_Log().SetUserID("actPredecessor2Count : " + actPredecessor2Count, user_id, logfilePath);
      for (int num = 0; num < actPredecessor2Count; num++)
      Item actPredecessor2R = actPredecessor2.getItemByIndex(num);
      Item Predecessor = actPredecessor2R.fetchRelationships("Predecessor").getRelationships("Predecessor");
      string predecessorString = "";
      int PredecessorCount = Predecessor.getItemCount();
      for (int pre = 0; pre < PredecessorCount; pre++)
      Item RelatePredecessor = Predecessor.getItemByIndex(pre);
      string related_id = RelatePredecessor.getProperty("related_id");
      Item PredesActivity2 = inn.getItemById("Activity2", related_id);
      if (string.IsNullOrEmpty(predecessorString))
      predecessorString = PredesActivity2.getProperty("nd_number");
      else {
      predecessorString = predecessorString+","+ PredesActivity2.getProperty("nd_number");
      //string nd_predecessor = "";
      inn.applySQL("update innovator.Activity2 set nd_predecessor='" + predecessorString + "' where id='" + actPredecessor2R.getID() + "' ");
      // new ND_Log().SetUserID("Successor Name: " + actPredecessor2R.getProperty("name") + " predecessorString Name:" + predecessorString, user_id, logfilePath);
