jon_deeks_ssi-corporate_com
2 years agoIdeator III
PDF Viewer doesn't support clickable links - true?
It looks like a PDF opened in the PDF Viewer doesn't support clickable links in the text, that are clickable when the PDF is opened directly in Adobe, or opened in a new browser window off the Files ...
- 2 years ago
An update. I've had a back and forth with Aras Support. They have done some investigating and clickable links should work in PDF Viewer and do usually work.
The example I shared above, in a PDF that Aras produced (the Essentials training guide), is an exception. They don't understand why that one doesn't work, other links in the same document do work as expected. Seems I was just (un)lucky using that PDF when I wanted to try it out.
So links should work.
