8 years agoAccelerator III
Part, Document and CAD Document Revisions
Hi All,
This is in part a philosophical question and in part looking for advice from people who have implemented the Mechanical CAD Connectors with Innovator.
Before anything else I will say that I appreciate the physical part should not, in ideal circumstances, have a part revision stamped or otherwise identified on it. That is not how certain parts of the organisation see things.
As an organisation we have for many years directly linked our physical part revisions to the Mechanical CAD Model revisions. Physical parts will often have a revision identified on them and this revision directly relates to the CAD model data revision.
Now we are live with Innovator and about to start implementing the CAD connectors. This brings to a head a change that the organisation did not really appreciate until very recently. The Innovator Part Data (which I will refer to as the Part Metadata), Document Data and CAD Document data are all independent entities that can change their revisions independently and in some cases dependently.
This leads to the very real situation where, if you identify the part revision on a physical part, you have to ask which revision should be on the physical part.
Should it be the CAD model revision which fundamentally is the primary data telling you how to build a "thing" and only changes when it has to or should it be the Part Metadata revision that changes when any related Document or CAD Document changes?
I'm looking for input where possible from people who have encountered this themselves to find out how other organisations deal with this.
Thanks,
Brian.
