I think I understand what's happening. It looks like you're creating some new operations, but not assigning them any variables
Hi Orinwisozka,
Thanks for your reply. I am wondering what variables to be set here? Thanks.
Hi Jenli,
seems like Orinwisozka discovered something very important! I am not sure if I interpret this hint right, but I will try: Your empty entries in the search dialog seems to appear NULL relationships that are not assigned to related items / Operations. The regular OOTB code only use NULL relationships. With your reusable Operation you may have to tie your Operations by the property related_id to appear.
- Jenli5 years agoCreator I
Hi Angel, I totally agree with you guys and there should be something connect the existing Operation to ProcessPlan, I check into the DB mpp_ProcessPlanOperation Table and here is what I found, property source_id is ProcessPlan property id which is used to connect the Operation to individual ProcessPlan, and also property related_id represent for mpp_Operation property ID , which stands for mpp_ProcessPlanOperation is the relationship type of mpp_Operation. So, I am confused that anything else should be set here? Thanks!
Hi Jenli,
ok, db seems to be ok. You mentioned that you edited the removed.js. As you are already able to open the search dialog for inserting Operations, you seem to have changed a couple of other codetree files successful already.
Have you changed anything regarding the inserting of "related" Operations? Should be in removed.js. It contains a case for adding Operation. Compare it to the case used for ConsumedPart. Do you have something similar for your custom Operations?
