I think I understand what's happening. It looks like you're creating some new operations, but not assigning them any variables
- Jenli5 years agoCreator I
Hi Orinwisozka,
Thanks for your reply. I am wondering what variables to be set here? Thanks.
Hi Jenli,
seems like Orinwisozka discovered something very important! I am not sure if I interpret this hint right, but I will try: Your empty entries in the search dialog seems to appear NULL relationships that are not assigned to related items / Operations. The regular OOTB code only use NULL relationships. With your reusable Operation you may have to tie your Operations by the property related_id to appear.
Hi Angel, I totally agree with you guys and there should be something connect the existing Operation to ProcessPlan, I check into the DB mpp_ProcessPlanOperation Table and here is what I found, property source_id is ProcessPlan property id which is used to connect the Operation to individual ProcessPlan, and also property related_id represent for mpp_Operation property ID , which stands for mpp_ProcessPlanOperation is the relationship type of mpp_Operation. So, I am confused that anything else should be set here? Thanks!
