Hi Jen,
If I'm understanding you correctly, I think I understand what's happening. It looks like you're creating some new operations, but not assigning them any variables (name,desc, etc). That's why when you perform this search, there are two empty rows. They exist and have been saved, but don't have any identifying information so it appears that they're not there.
If I misunderstood the issue please let me know!
AJ
- asebastian5 years agoCommunity Manager
If you were to go into the mpp_processplanoperation relationship and make it visible, can you see the relationships in that tab on the process plan? I'm wondering if it's an issue when attempting to render the actual plan itself, or if the relationship isn't getting added for some reason.
Have you made any modifications to the standard MPP data model? How did you create the other process plans if you're unable to add operations?
- Jenli5 years agoCreator I
Hi AJ,I created the MPP_ProcessPlanOperation as relationship type of MPP_Operation which I added and modified for data model. Those mpp data I added before I made changes by using the standard version, Please see the screenshot, then I made change to open a search a dialog instead of manually inserting and find out the selected operation does not show up.
by the way, the mpp_processplanoperation has always been visible. Thanks.
Best,Jen
My recommendation was to unhide the mpp_operation relationship so you can view it in a relationship tab. You'll have to expose the relationsihps tab by unchecking the "select in all" button on the mpp_operation relationship.
Once you've done that, the MPP form should look like the following screenshot.
I wanted to see this view to see if the issue is saving the relationship, or if the render is unable to render the existing operations.
