Hi Sithen,
Can you post your error message? The image is not visible.
I don´t know, of onChange event can work in a chain. I haven´t tested it, but form a logical POV it should work. Maybe it´s some kind of timing issue. How do you trigger the change of field2 with the first onChange Method?
Hey Angela,
Here is the error message:
Internal Error: event handler failed. Event handler failed with message: 'func{0}8E75984331E43CF99381A8DF65662FA$_onchange0' is undefined
Client Side Error
The ID has changed because I tried remaking the method but that is essentially the error. if I check the DOM I can see that func{0}8E75984331E43CF99381A8DF65662FA$_onchange0 exist and has my code within it.
maybe it is a timing thing? but I have not made any forward progress on this problem
