hkhan's avatar
hkhan
Not a single item
I wrote down the following to get data from a relationship and insert it in an item type but unfortunately im having the following error
I dont see an issue with my logic if someone can take a look i would really appreciate it.
Not a single item
Item ecrtask = this.newItem("ECR Task", "get");
ecrtask.setProperty("source_id", this.getID());
ecrtask = ecrtask.apply();
for(int i=0; i < ecrtask.getItemCount(); i++)
Item relDoc = ecrtask.getItemByIndex(i).getRelatedItem();
string title = ecrtask.getProperty("vsy_title","");
relDoc.setProperty("vsy_title",title);
string relDocid = relDoc.getProperty("id","");
string sql = "update [innovator].[VSY_Task] set vsy_title = '" + title + "' where id = '" + relDocid + "'";
Item result = inn.applySQL(sql);
  • Can you please help me to understand relDoc.setProperty("vsy_title",title); ...?
    • hkhan's avatar
      hkhan
      Kindly ignore that I forgot to comment that out
      • SunilReddy's avatar
        SunilReddy
        int countOfECR=ecrtask.getItemCount();
        return this.getInnovator().newError(countOfECR.ToString())  ///Try to get Count and see if it is returning Zero records or more
        Item vsyTask=this.getInnovator().newItem("VSY_Task","edit");
        vsyTask.setAttribute("where","[VSY_Task].id='"+relDocid+"'");
        vsyTask.setProperty("vsy_title",title);
        vsyTask=vsyTask.apply();
