Hi Eli,
thanks for the ideas! I made some progress and at the same time you opened Pandora's box.[emoticon:d6dd260102fd406884fc96b8bc59760b]
The original idea was that I reuse my custom "all-purpose-all-in-one view". It´s a single Method that renders the result of an AML query to a simple table in a pop-up window. See following example. It uses a AML query to collect all documents hidden in the multiple BOM levels:
That´s why I asked for the plain AML query - cause I wanted to use the same building technique to "save time" (worked well so far[emoticon:0f36700dfeb3494fa10d47dd9e1f90a1]).
As this kind of rendering is basically a simplified QD/TGV clone, there is of course nothing wrong with using the original QD/TGV combo. The resulting view is basically the same and QDs can deal with referencing items. Perfect!
Quote: Out of curiosity - do you have any constraints preventing you from using a Query Definition in this scenario?
There were none - before I tested it. In my environment it doesn't work, but it´s not the fault of Innovator. It´s my federated data that I pull via an onGet query.
My current federation solution is optimized to display federated data in the client (including grid relevant functionality like filter options, paging, etc.). See: link
Now I learned that my federated data isn't perfect enough for AML queries. My "crafted" item properties mainly consist of id and keyed_name. With id and keyed_name they work as clickable links in grid and Forms, but they doesn't work in QDs.
I think we can tell the reason when we look a the data structure of similar ItemTypes (like Manufacturer Part with the Manufacturer item property). Typically item properties use a bit more data:
I am right now a bit unsure of what to do.
- Use an additional server Method (as you suggested)
- Rework my federation solution so I can use QD?
- Make an additional federated view that already contains all the data?
- I also got some ideas from another community member that I don´t need to over engineer everything and there is nothing wrong in using more than one AML query to get the data.
I think I'll let the problem sit for a while and hope it resolves itself. It´s a fun challenge, but it´s just there because my users are spoiled. In the past people would have been totally fine with an SSRS report for this kind of view.[emoticon:d6dd260102fd406884fc96b8bc59760b]
Edit: In QD I right now get following error message when testing the query: <faultstring>Item attribute 'itemTypeName' not set !</faultstring> . In only appear when my custom federated ItemType is included. For testing purposes I added various additional attributes, but couldn´t get rid of the error message.
I made some progress. I solved the original use case by making an additional SQL view. Not my favorite solution, but this way I was able to read the data with a much simpler AML query.
But this topic is still a rabbit hole regarding the query definition.
I so far didn´t succeed in using my federated ItemType inside a QD. Even if I create a completely new QD with just the Federated ItemType I get the "<faultstring>Item attribute 'itemTypeName' not set !</faultstring>" error message.
And I think I know the reason. QDs work different than the Grid. Right know my federation onGet query is optimized for the classic "Grid - Relationship - Form" trinity. But QDs work different, as they support more additional functionality like levels and reverse properties. My Federated ItemType cannot work, cause it doesn't provide the data that a QD needs. I right now just return the regular item structure but QDs works a lot with references.
eli_donahue Do you know if there is any information of the basic data structure a Query Definition uses when pulling data? It´s not an important topic right now, but I see a lot of fun use cases for these kind of queries.
- eli_donahue1 year agoCommunity Manager
I can check with the PM and architect for QD to see if we have any info to share. Using federated data in QD’s certainly sounds like a helpful use case.
PS: “We have an item property at home” gave me a good laugh [emoticon:752f32bcc91d4a448db162742a877a4a]
