DucTran's avatar
DucTran
My web Asp.net login failed
Hi everyone,
I have to make a web with ASP.NET and published to host http://inn.ddns.com/myweb. The web accessed normally.
The login form has:
--> When a press login button, nothing happen (no alert failed or succeed, no error string)
If I replaced server address by local name (http://inn-srv/myaras), It working fine.
I try to config IIS server, open port, .. but not succeed. Pls help me.
  • Do you have extended the redirectUrls in one of the OAuth Config?
    • DucTran's avatar
      DucTran
      Could you explain more detail?
        Take a look at the file...\Innovator\OAuthServer\oauth.config. There is a block with redirectURLs. When you use a different url (typically when you change to https), you must add it there. In my case, I also had to restart the Oauth apppool. And check for error messages in the browser debugger.
  • Hi
    U equally need the following Parameters
    grant_type=password&scope=Innovator&client_id=IOMApp
    These are in your Web.config
