3 years agoCatalyst II
Hi Meismart,
are you still doing PLM? I right now face the same issue that you had 5 years ago.
I get the same error message. Certain physical files have been removed from the Vault, but they still appear in the "File" table.
I would prefer to clean up the wrong entries in the "File" table, but don´t want to erase the data directly in SQL.
One idea I currently have is to rebuild the missing folder structures with fake files and then finally delete them again.
But I wonder if you have found a more elegant solution?
Thanks and best regards!
If anyone else knows a good solution to this one, please let me know!!!!!
Solved it! I didn´t skip the problematic files entries, but repaired them so I finally was able to delete them like regular files.
