7 years agoCommunity Manager
Hi Angela,
I tested this in an SP11 instance, and I can confirm that the grid didn't load as expected. Looking at the
revisionDialog.html, I believe this is an issue with the Grid trying to pull the columns to display from the cache. I was able to see the grid by making the change below to the initGrid() function of the revisionsDialog.
function initGrid() {
var colWidths = topWnd.aras.getPreferenceItemProperty('Core_ItemGridLayout', itemTypeID, "col_widths");
var colOrder = topWnd.aras.getPreferenceItemProperty('Core_ItemGridLayout', itemTypeID, "col_order");
if (itemTypeName == "Part")
colOrder = "L"; // Add a default column of the Lock state
colWidths = "24";
