7 years agoCatalyst II
Hi Andreas,
thanks for testing! Which Aras version did you use? Did you do anything else despite deleting the browser cache to trigger the codetree change?
I currently use SP11, but just could not get this one running.
My customized revision history will only contain one grey box, propably the table header for the lock column. But no additional columns and no rows are displayed.
when I debug the code, the property visiblePropNds contains my filtered properties. So the xpath definitely works.
All item ids are returned and the grid_xml will contain the complete html code for rendering the table, based on the filter.
I somehow assume it´s related to the xProperties (which I don´t use yet).
