8 years agoCatalyst II
Yeah, I also did this once. I changed the Default Revision Schema from "A B C" to "V B C" just to see what happens. This was the official solution from support:
A quick solution is to edit the database:
- Start SQL Server Management.
- Expand the database InnovatorSolution and expand Tables, locate the table innovator.REVISION.
- Right click and select Edit Top 200 Rows.
- Change the value in the Revision-column to "A B C D”
