4 years agoCatalyst II
Hi Douglas,
you mainly have to customize the used "Document Type" and "XML Schema Elements" inside the database. I don´t think this one requires a lot of codetree modifications, but it has been a while since I did this kind of stuff.
DouglasW
4 years agoIdeator II
I was able to successfully edit the "Document Type" and XML schema to add my "Procedure" at the same level as Operation. Unfortunately, doing so is only one piece to the puzzle. You definitely have to edit the code tree javascript under "innovator\client\Solutions\MPP" to make it go further. I am to the point where I can add the Procedure but it doesn't show in the Process Plan tree despite being available in the database. Still plugging away at it and hoping that Aras support will provide some insight.
