Meismart
9 years agoCreator III
You are currently hard-coding the Lifecycle states into the Method to check if they are released, you will have to modify the code to match the new state names of the released states.
string[] ReleasedStates ={“In Design”,”Prototype”,”Active”, “Inactive”, “Obsolete”, “Discontinued”};
The second option would require more work, but you may be able to look at the Item property "status" and retrieve the released property that way.
