silje_dahl's avatar
silje_dahl
Ideator II
JS in Item view: Why is document.thisItem.node.childNodes modified on lock/unlock?
While running a method OnFormPopulated, I reference the list document.thisItem.node.childNodes to get an overview of the properties of the current item. This NodeList contains all elements on first...
  • Gopikrishnan's avatar
    Hi Silje Dahl
    This is because
    When the item is loaded, nodes will have all the properties
    When the item is locked, nodes will have only the properties which is having values
    When the item is unlocked, nodes will have only the properties which is having values (Locked By ID is empty in this case). So, this will be always (locked nodes count - 1)
    Thank You
    Gopikrishnan R
