Nathan_H_
2 years agoAccelerator I
Javascript Temporary Permissions
Good day all. I'm still using v11 SP10. How do I grant temporary permission for a user through Javascript? I want to add a Comments tab to our custom change ItemType. I have a script attached to ...
- 2 years ago
You cannot grant temporary permission for a user through Javascript. In general this is impossible.
Just image somebody builds his own Aras Client and is able to influence permission this way. This way regular users could transform themselves into root accounts. Would be a great way to hack a system!
What you want do is not a uncommon task. I do the same in my own dialog calls. You need an additional Server Method that is called from the dialog. The Server Method uses GrantPermission so you can execute the query with Aras PLM or similar rights. You should be able to find GrantPermission samples online. Even Aras use this technique.
- 2 years ago
Angela,
Thanks for confirming this. I had thought that was the case.
