9 years agoAccelerator III
Maybe an admin could delete the post #9574 which has the issue in it.
There is some type of layout issue in Chrome 58 when I posted that URL to the form and it will not let me edit it or delete it.
Just to continue. I gather Common Grid Utilities allows different Grids to be loaded from XML definitions stored on the file system. Most likely I could just reconstruct the ItemTypes (tgc_Configuration, tgc_Constant, tgc_*) working backwards from the definitions I have, but that seems kind of silly.
I have merged both Collaboration Folders and Item Characteristics Packages successfully. Both fail when they attempt to load their configuration grid data from the XML file during runtime, due to the missing ItemTypes.
www.cascadeacoustic.com/.../tgc_Configuration.png
