jamar's avatar
jamar
8 years ago
Issue with report creation - Method and AML
Hello, We currently don't have self service reporting and I am trying to create a report but have ran into an issue. I have created one as a method (to be ran though the reports drop down) and one as AML but neither work. I can't work out how to get this to display in a tabulated format, get the error "Line number 40, Error Number: CS0029, Cannot implicitly convert type 'string' to 'Aras.IOM.Item'" on the "return html" line. The method searches through all ecr records and if they are within the last month and have a change type of defect it will display the records found. The method works if I say "return inn.newResult(result);, but cant convert into the   Innovator inn = this.getInnovator(); Item ecr = inn.newItem("ECR","get"); ecr.setAttribute("select", "item_number, source, trl_product_family, state, trl_change_type, created_on, trl_sup_total_cost_of_change"); ecr = ecr.apply(); string result = ""; // Specify Dates DateTime today = DateTime.Today; DateTime month = new DateTime(today.Year, today.Month, 1); DateTime first = month.AddMonths(-1); DateTime last = month.AddDays(-1); //return inn.newResult(Environment.NewLine + first + Environment.NewLine + last +Environment.NewLine); if (ecr.isError()){ return ecr; } int totalecrswithdefects = 0; for(int i=0; i<ecr.getItemCount(); i++) { Item curr_part = ecr.getItemByIndex(i); string e = curr_part.getProperty("item_number",""); string h = curr_part.getProperty("trl_change_type",""); DateTime d = DateTime.Parse(curr_part.getProperty("created_on","")); if (d.Date>first.Date && d.Date<last.Date && h == "Defect") { totalecrswithdefects++; result = result + Environment.NewLine + e + " " + h + " " + d; } else { continue; } } var report = inn.getItemByKeyedName("Report","newlostcost"); var style = report.getProperty("xsl_stylesheet"); var html = ecr.applyStylesheet(style,"text"); return html; OR: I also cant work out how to use the "less than" operator in the below for the section "and [ecr].created_on<" I get the error:- '<', hexadecimal value is an invalid attribute character. <AML> <Item type="ECR" action="get" where="[ecr].created_on>DATEADD(month, DATEDIFF(month, -1, getdate()) - 2, 0) and [ecr].created_on<DATEADD(ss, -1, DATEADD(month, DATEDIFF(month, 0, getdate()), 0))"</Item> </AML>   Any ideas?
  • eli_donahue's avatar
    eli_donahue
    Hi Jamar, The error you see occurs because Aras methods must return Items if they return anything at all. You can return your HTML string by wrapping it with an Aras result item: Item result = inn.newResult(html); return result; Eli
