Could you share the JavaScript you're using to get the key from your resource file? Additionally, can you confirm that the name of your XML file is ui_resources.xml?
Hi Chris,
Please let me know if you have any solution for this?
I wasn't able to reproduce this issue in a local instance of 11.0 SP15 I have running. I added a folder called DR to my local instance and put a ui_resources.xml file in an /xml/ folder there. After that, I was able to get the resources I had defined by using aras.getResource("DR", "my_resource_key"); .
Could you let me know what version of Aras Innovator you are using? You can check this under Help > About in the main menu of Aras Innovator. Additionally, can you try clearing your browser cache? It's possible an old cache is causing the new file to not be recognized.
