7 years agoCommunity Manager
Could you share the JavaScript you're using to get the key from your resource file? Additionally, can you confirm that the name of your XML file is ui_resources.xml?
7 years agoAccelerator III
Hi Chris ,
Thanks for replying.
Name of my XML file is ui_resources.xml.
I also tried copy pasting XML file from PLM/xml folder to my DR/xml folder. But I can't access that XML also.
JavaScript content is some business logic, which unfortunately I can't share here. But there is only one line which deals with accessing data from this file -
var text = aras.getResource("DR","test");
if i try
var text = aras.getResource("PLM","xxxx") - it works. xxxx = some id already present in ui_resources.xml
