DaanTheoden's avatar
DaanTheoden
Creator III
4 years ago
Instruction: Removing the Enterprise Search Toolbar in Aras Innovator V12
Hello everyone,
Here is a short instruction on how to remove the Enterprise Search (ES) bar when logged in into Aras V12. This can be helpful to prevent confusion amongst end-users if you decide not to use the feature.
Before:
After:
This can be achieved by taking these steps:
  1. Open the TOC and go to Administration > Configuration > Client Presentation
  2. Perform a search and open the single record that you find named 'JavaScript'
  3. On the 'JavaScript' item, click on the 'Global' item / URL
  4. On the 'Global' item, open the 'Command Bar Section' relationship and expand the 'Name' column
  5. Scroll down until you find an item with the name 'com.aras.innovator.mwh_es_toolbar' and open it
  6. In the 'Command Bar Item' relationship, find the button 'com.aras.innovator.mwh_es_search_button' and set the action to 'Remove' instead of 'Add'
I hope this helps. All the best from Almelo.
Daan
  • Hi Daan,
    thanks again for sharing this one! This on is indeed a useful customization, as a lot of user don´t use (or cannot use) Enterprise Search!
    • DaanTheoden's avatar
      DaanTheoden
      Creator III
      Hello Angela,
      Thank you again for your reply! I indeed think the ES bar should be hidden out-of-the-box.
      Daan
