Hafedh_Elfaleh's avatar
Implement a method that calls a method in a DLL
Hi all , Please how to Implement a method that calls a method in a DLL? Thanks .
  • Suhas's avatar
    Suhas
    Below is the link for how to create DLL in VS:
     https://www.c-sharpcorner.com/UploadFile/1e050f/creating-and-using-dll-class-library-in-C-Sharp/
    1. Copy the calculation.dll in server bin folder  e.g.(C:\Program Files (x86)\Aras\Innovator\Innovator\Server\bin).
    Register your dll in method-config.xml file (C:\Program Files (x86)\Aras\Innovator\Innovator\Server)
    1. Open method-config.xml file :
    2. Add your dll the namespace under <ReferencedAssemblies> xml tag
    3. Add your dll reference in <Template name="CSharp">
    Create your method in Aras and call your dll method from aras method.
    Thanks and regards,
    Suhas
  • Suhas's avatar
    Suhas
    Hello Hafedh,
    In which .net framework version you compiled your dll?
    Please make sure your dll should be compiled in .net framework 4.0.
    Regards,
    Suhas
