7 years agoCatalyst II
Maybe your toggleSpinner needs some additional code to be displayed correct? The Method 'VCN_OnShowItem' also uses this element, but it uses additional code to display the spinner on top position (as far as I understand the code...).
greek
7 years agoIdeator III
Thanks for the suggestion. I tried already that but still the same behaviour.
var topWnd = window.TopWindowHelper.getMostTopWindowWithAras();
aras.browserHelper.toggleSpinner(topWnd.document, true);
