Hi Breton,
Funny to see how many people still use Innovator 11.
Solution for question is much simpler: You can use the "Default Search" property in the ItemType definition. Just go to your Properties in your ItemType. There is one column far right that you can use.
hello, we are migrating to new ARAS version ! :-)
thanks for your answer but I saw in documention
so, after testing, it is not work fine !
it is why I tested with an event (OnSearchDialog) on state property with no effect too :-(
Oh that´s has to be something new. Default search still works in my Innovator 12.
Which version do you use for testing? Where do you have seen this note?
You can either ask Aras or as alternative: Investigate how Aras itself solves it. Aras use "Default Search" values in a couple of itemTypes like "dr_RelationshipFamily" or "Project Task".
Would be curious about the solition! :-)
Cause I had the window still opened. --> "dr_RelationshipFamily" as sample was wrong. But in Innovator 12 "Project Task" used Default Search for "my_assignment" and "status" property. Maybe in your version Aras solved it with a Method. Would be worth a try.
- Breton4 years agoIdeator III
hello, as we are on migration to aras17, I will use functionnalty later.
I checked on aras 17, It works fine..! :-)
So, I will wait.
thanks a lot for your reply
