miraks
5 years agoCreator II
Hi Angelalp,
Thank you for your answer.
If my method is like this:
return this.getInnovator().newResult(new Newtonsoft.Json.Linq.JObject
{"return_code", 0} ,
{"message", "hello world!"}
}.ToString(Newtonsoft.Json.Formatting.None));
The output is a text:
var item = this.getInnovator().newItem();
item.setProperty("json", new Newtonsoft.Json.Linq.JObject
return item;
So, you are right, with your solution the output is well a JSON.
But a JSON of an Item. Is it possible to send a fully customized JSON ?
Regards.
5 years agoCatalyst II
Hi Miraks,
standard Aras Method just can return items. "Results" and "Error" are also just items.
Maybe you can use some kind of custom class or other more native C# techniques, but I am not sure. Some times you see these kind of designs in native Aras code.
